ive got my first track day (afternoon,4 hours) at mallory this week and was wondering how much fuel im likely to need to take with me?
and roughly how much track time would you generally do in 4 hours? do you split it into say 20 mins on 20 mins off or just go out for maximum time?
cheers
I have only done a couple , with my Westfield , but have been to a few with my son and his Westfield. The main thing is not to over do it. Its very
easy to just go out there and wack it round and round. I would certainly start of with perhaps 10 mins max ,come back in check the car over,
especially brakes and tyres and pressures. Get back out for a bit longer , I personally would say 20 mins max, and gradually build up your speed ,
braking etc. Dont be tempted to stay out any longer. Decent break , let the brakes cool down , have a chat and a coffee , then do it again. Do keep an
eye on the car especially the brakes and tyres and pressures. you would be surprised how much strain a track day can put on a car compared to giving
it a bit of a blast on the road. Have a great day.
MikeF
Sorry should have also said, that to start with we always used more fuel than we thought we would, I would estimate about 25% more than your normal consumption, could be more.
Daniel when are you there? I'm only a couple of miles away
thanks mate!
friday afternoon oli! 1pm until 5pm! £99 and still spaces left
I take 2 full gerry cans plus a full tank (about 3 gallon tank) and that does me to drive there (about 30 miles) do the track day (every session
I'm allowed out in over a full day) and enough to get to a fuel station on the way home
So in summary about 55 litres does it for me, fuel consumption on track is horrific due to the constant revs.
If you get double digit MPG, you're not trying hard enough.
The best I have managed is about 10 litres in a 20 minute session. I would say I usually only get about six of these sessions in one day around
checking tyre pressures and for loose bolts / chin wag, fitting an extra silencer / lunch.
Would also recommend at the start of the day keeping an eye on other cars from the pits to identify drivers to avoid before heading out - we had a
Nissan GTR on his first trackday at Donington who kept missing his braking points, resulting in him overtaking people on corner entry, sometimes even
on the wrong side.
My bro and I did a £50 tank in his MX5 over an open day at brands in the damp. The damp kept speeds down, but also kept tyre and brake wear down allowing us to run it almost constantly throughout the day relaying between the 2 of us.
I will do 75 litres in a open pit lane full day, fill your tank to 3/4 to make sure no fuel sloshes out on hard bends and a full 25litre jerry
can.
Best to have a little to much than run out.
You have a perfect run of the mile car. I would not worry about brakes unless you know some thing we don't. I wont know what tyres you have but
if they have tread on them you should be fine. Fuel wise depends on how heavy your foot is. If this is your first track day then 50 litres is a good
guess. How you take it there is up to you. I have never noticed the difference of full and empty. I do feel the difference of normal and high octane.
I think the key to you enjoying your day is none of the above. The best advice for new track day people is to enjoy and do what you want. Sounds silly
but take the advice. The first track day I did I was doing 40 min sessions by the end on a OPL. I drive harder now and do anything from 15 to 35 mins
depending on who and what is on track. If your doing OPL the key is timing. Go out as others are coming in. Notice when your loosing concentration and
when you want to push.
I have set fastest laps normally after 10 laps on an empty track. My last track day had a fastest lap on the 19 lap! That's about 20 mins in.
Most of that was spent chasing space.
Take your time and enjoy.
[Edited on 4/5/13 by bi22le]
I always spend more on fuel than on the track day itself.
