just spotted this on the bay,
I remember tiff diving the z100 twin engined tiger, breaking the world 0-60 recod, then breaking the car lol
In my head I would imagine it to be almost if not impossible to get the engine running totally in sinc. This mini has both the engines linked up to
the same axle/drive box, no chain.
Has anone got any experince of thise? is its possible to get them to drive reliably then I would imagin it is a very cheap way of geting a 12k rpm 8
pot 300+bhp powerplant.
Any comments would be great
Link?
They don't have to run totally in sync, you can happily change gear at different times too if you like (within limits). Two people pushing a car
makes it easier than one, even if they've got different length legs, they don't have to step perfectly together. All you have to do is
ensure neither person pushing the car exceeds their max speed (and thus falls over) or is so feeble they add nothing to the game. think about it this
way, all pistons don't produce the same torque even within a normal engine. Too much imbalance and you snap a crank but that's just a design
strength issue. Leave them totally separate or link them at the gearbox output, either way they'll work together.
Ultimately I think it's harder to get the full benefit of two engines without massive rotational inertia issues and ending up with a lower
power/weight ratio than just one decently tuned engine though.
Do a search, I and others have investigated this a few times and concluded it's not worth the hassle.
[Edited on 9/5/13 by coyoteboy]
twin r1 engine mini | eBay
sorry chaps
Originally posted by coyoteboy
They don't have to run totally in sync, you can happily change gear at different times too if you like (within limits). Two people pushing a car makes it easier than one, even if they've got different length legs, they don't have to step perfectly together. All you have to do is ensure neither person pushing the car exceeds their max speed (and thus falls over) or is so feeble they add nothing to the game. think about it this way, all pistons don't produce the same torque even within a normal engine. Too much imbalance and you snap a crank but that's just a design strength issue. Leave them totally separate or link them at the gearbox output, either way they'll work together.
Ultimately I think it's harder to get the full benefit of two engines without massive rotational inertia issues and ending up with a lower power/weight ratio than just one decently tuned engine though.
Russ's F1 road car had twin bike engines, each driving it's own rear wheel.
Ultimately an engine is something that provides torque, couple two engines to the same axle and the torque simply adds. In principal this is no
different to having an engine with more cylinders, except the torque is combined after the gearbox rather than before.
The Mini twin R1 uses a Berrisford/autograss drivebox, and these dont have a lsd. The vehicles Ive driven on roads with locked diffs were my Lada/Land
Rovers and several 4x4 - 6x6 trucks, and they all wound up pretty quickly.
Apart from single engine running, these cannot be very much use on the road ?
