I've bought a power commander III for my GSXR 1000 K1 off eBay but it appears to be an old type with a serial plug, not USB.
Anyone using this older sort? Its got a couple of extra plugs (white ones) on the harness that I don't recognise. Where would these plug
into?
Will this work with a serial to usb adapter from eBay. not sure whether to return and wait for a usb one.
USB to serial works fine - you need to download the power commander 3 software from their website.
Also, don't try and upload any map files - they need to be a certain version because the USB and the Serial PC3 uses a different language which
are not compatible.
I've got a name and number for the tech support guy at power commander who was REALLY helpful and knows his s**t if you need it
is it a IIIr??
they look like ignition loop connectors for advancing the ignition timing that came on the R series..
I use a serial PC3, and mine has two red connectors just like those. They connect inline with the brake light wiring as the power source for the PC3.
that's not a K1 /K2 power commander, i have one and it just has the 2 plugs and an earth. whats the part number on the side you need to google it
and see whats its for.
it should be 307-410 or 307-411, 308-411,309-411
PS are you wearing green trousers
Originally posted by Dopdog
that's not a K1 /K2 power commander, i have one and it just has the 2 plugs and an earth. whats the part number on the side you need to google it and see whats its for.
R means it can do ignition advance..
I would phone dynojet up on Tuesday, they will tell you what you have and what you can do with it.
its means you can adjust the timing to advance the firing point of each spark plug..
the 2 white connectors are a loop and go inline of the crank sensor..
I have today stole the pc3 usb of my k6 1000 and fitted to a k1 engine in my MK.. It does work and you fit it the same way you do on the k6.. loop
each injector and plice into the pink and black/ yellow tps wire.. run the ground wire to earth and hey presto mappped for IVA inta monring...
sphinxers flapping now..
