Evening,
I'm about to start building my locost and am trying to make up my mind about which engine and so on and wondered if anyone could offer any
advice...
I've been driven in a zetec westy and a blade fury so I know a bike engine is what I want, I just don't know which one.
I'd like FI but can fit it to a carb'd engine if need be. I'd like a blade engine as I have a blade and have had it for 3.5 years from
new and it's been rock solid. If I go for an FI blade engine do I need a dry sump or can I get away with a shallow baffled sump? Is the late R1
engine better or more or less the same? Does anyone have any other recommendations for an engine? I have a budget of about 1k I guess but would
obviously prefer to spend less.
The BEC I was in today was very very nice but the gear changes were very clunky. This doesn't happen on my bike and my guess is that this is
because the bike has a cush drive and the car did not. Is there a similar device available for a BEC that soaks up some of the shock on a gear change
as there is on a bike?
Thanks,
Mark
PS. Another quick question... I want a LSD to go in this project, do any of the sierra LSDs have a suitable ratio for a BEC?
[Edited on 10/10/04 by dern]
to answer the ones i can............. not all of them!
The clunky gear change is a characteristic of a BEC as far as i know, no one i know has bothered with a cushdrive of any sort.
As for LSD, its a case of is the engine suited to the LSD or is the LSD suited to the engine, some bike engines are better suited to your most common
LSD's (3.62) fireblade, R1, ZX9 will all go well with a 3.62 other nike engines have differing output ratios.
Do a search fo gear ratio calcuator on here and have a play about with diff ratios and different bike engines.
all the best
I have a cush drive of a sort - torque resilient tube in the rear section of the prop, can't say whether it makes a difference, but other than
1-2 all the changes are fairly painless.
Kingr
quote:The gearchange on my fireblade from 1st to 2nd is pretty clunky and it has been on every bike I've had so that sounds pretty good.
Originally posted by kingr
I have a cush drive of a sort - torque resilient tube in the rear section of the prop, can't say whether it makes a difference, but other than 1-2 all the changes are fairly painless.
quote:Thanks for that, I'll have a play with the gear ratio doo-dahs later.
As for LSD, its a case of is the engine suited to the LSD or is the LSD suited to the engine, some bike engines are better suited to your most common LSD's (3.62) fireblade, R1, ZX9 will all go well with a 3.62 other nike engines have differing output ratios.
They don't make life any easier for the gearbox, they save the chain on a bike. I have a shaft drive bike and it doesn't have any cush drive. If you don't have the brake on hard when you select a gear it seems to go in easier.
quote:Some shaft drive bikes do have a cush drive to damp down the shock of a gear change. Some guzzis have the cush drive built into the clutch (dry clutch) and the honda pan-european has a damper in the drive shaft (no idea how that works) and a cush drive in the rear wheel for example(s). I'm not saying all shaft drive bikes have or even need one but it would appear that the use of one is not limited to chain driven bikes.
I thought I had a lot of decisions to make *before* I downloaded the gear calc program
As a first stab...
code:
GearCalc v2.0.0.3 Copyright ©2001, Peter Ogden
Gear Ratio, Speed and RPM Calculator
Gear set: Manually entered values
Gear 1 2 3 4 5 6 Final
Ratios: 2.692 1.933 1.600 1.400 1.285 1.190 3.620
RPM Limit: 7895
RPM @Peak Power: 6578
Tyre Size: 185/70 x 13
Tyre Diameter: 23.20 in
Tyre Circumference: 72.88 in
Gear Mph per 1000 RPM Mph @6578 RPM Mph @7895 RPM
1 7.08 47 56
2 9.86 65 78
3 11.92 78 94
4 13.62 90 108
5 14.84 98 117
6 16.02 105 126
