I probably know the answer to this one, the rads could do with a bit of alloy sheet either side to promote air flow ?
Just remember that air WILL take the path of least resistance
So the air will just go round your rads, not through
Where on your car is it and what is it a rad for?
Could you not just angle it up and block either side?
Why are you against channelling air in? Asthrics could be improved with some sensible grilling.
Not enough space to get them side by side with good flow through both then?
Loving your build by the way.
