Hayabusa Gearbox
hkp57 - 9/11/13 at 10:54 AM
Has anybody fitted the Big CC racing billet wide ratio gear set to a road going BEC.
What is you impressions of it?
What Final drive and tyre size were you running?
Link Here
daniel mason - 9/11/13 at 11:06 AM
it would be considerably cheaper ti fit a 3.14 in the back!
hkp57 - 9/11/13 at 12:10 PM
My question is about the shorter first gear and wider ratios, a taller Diff is not always the answer and makes the long first gear worse.
I know what the cost is.
imp paul - 9/11/13 at 04:12 PM
this mite save you some big pennys as big cc has stuff made here http://www.novaracing.co.uk/default.htm
cheers paul
