Bulkheads - Bond or Rivnut ?
T66 - 1/12/13 at 01:02 PM
The bottom portion of my bulkhead is rivnut fastened , to give me good engine access once built, however I am trying to avoid drilling the main hoop as much as possible. Whats the verdict on how to fix the top piece in, its alloy ? Not used any of the modern bonds before, are they removable should I need it out?
Plan is to use a 50mm wide piece of alloy angle to create a nice edge on the step between the lower bulkhead and the top section.
harness holes and rear view mirror will be fettled later.
rdodger - 1/12/13 at 02:53 PM
Can you weld tabs to the bar and bolt to them?
40inches - 1/12/13 at 03:22 PM
Polyurethane adhesive will do the job, you may have a problem if you need to remove it though.
T66 - 1/12/13 at 04:27 PM
I dont anticipate removing it, but then never say never. Ive used welded tabs elsewhere, so I think i need to buy some more strap.....
Like the simplicity of tubing an adhesive on it, but if it doesnt come off, probably not the best choice. Thanks guys
Ivan
