Just mulling over the power take off from my Suzuki TL, I cant find out what spline other suzukis use??
The sprocket I have is 13 spline, and quickly measured the shaft is about 25mm od, what else uses this size,??
Check this auction out http://www.ebay.com/itm/NEW- SUZUKI-FRONT-SPROCKET-GSX-GSX-R-TL-DL-SV-HAYABUSA-V-STORM-KATANA-520-13-TH-/221021529600 it will let you know which bikes use the same spline.
Thankyou, That just about covers all I need to know
