Hello,
My first post following on from buying a BEC...
I'm wondering how much oil I should put in when doing an oil & filter change.
The engine is a fireblade 893cc, with an Andy Bates billet sump.
893 has a dip stick, fill to max then add an extra 200ml, notch the stick at this height for future reference.
Regards Mark
As above but I was told 100ml
You can run Honda engines full to the brim of oil, Suzuki engines you cant.
