hi
cant figure this out.
2005 engine
think I run from.......... tanks > filter > low pressure pump > swirl pot then return from swirl pot to tank.... so that takes two of the
four connections on the swirl pot.
however now I get stuck, ...........so do I then take a feed from swirl pot to filter > high pres fuel pump > fpr > rail, if so how do I
return to swirl pot? or do I tee off after high pres pump to rail and reg then send return to swirl pot from fpr
any help greatly appreciated
Swirl pot needs fuel in at an angle to make it swirl, you should then have 3 pipes at the top and one at the bottom.
Bottom is fuel out to HP pump, HP filter then fuel rail.
Fuel Rail return goes to a side entry on the swirl pot with the second side entry being taken by low pressure fuel in (making it swirl) the top most
tube use as fuel tank return.
Regards Mark
Hi mate, if you haven't got it sorted I'll show you when I pop round on Friday.
thanks
