Hi, in desperate need to know what way the water flows on the r1 5pw. It's to plumb the water lines up for my turbo
Thanks in adavance
On which part of the system?
Just need to know if the water pumps up through the engine,then to top of rad. Or does it flow from the bottom of the rad to the top.
Hope that makes sense
Thermostat is in the pipe going to rad, so that's the hot water exiting the engine.
The waterflow is from the lowest point - bottom and upwards. Download the service manual for the motorcycle and you will have a wonderful description there with photos.
