just picked up a universal starter relay for the blade need help as to what wires go were.... my plug goes on but I'm confused as dodgyroger says
cut the red one out.... which would leave yellow/red to sierra switch ..... green/red to earth.....red and white to rectifier.....one terminal to
battery the other to starter motor am i correct... how does the battery get it's charge. isn't that what the red wire was for...
by the way it appears my rectifier that i asked for help over is off a cbr 1000
tony
if you aint had a reply by the time i get home 2morrow i'll nip in garage n have a look for you.
