So i want to make my zx10r powered mac#1 worx even more metal so thinking of the super charger rout , so ideas? info? experience ? what you thinking ?
I'm thinking you should learn to proof read.
Davie
I want less metal and more carbon...
Is there a version of the ZX10r motor used in a snowmobile? A lot are supercharged and you might be able to use the bits on yours. I know there is a
version of the R1 used in one and with a few mods' the 'charger from that can/has been made to work on the bike engine.
http://www.aaperf.com/zx10r-kit.html
-not trading anymore but gives you a list of what you need, give TTS a call I am sure they may be able sort you out.
Baby rotrex c15 i think
Mountain formance do sc kits for some snow mobiles as Adi touched on
http://viper.mountainperformance.com/
[Edited on 13/2/16 by hobbsy]
Davie
Personally I'd go more gangsta
I think that TTS Performance have done a ZX10R before but you will need to check with them. Be prepared to spend big money as none of these things are cheap.
Bike engines are harder/more expensive to get a supercharger drive from, turbo is a simpler option.
Want to buy a Turbo one?
you had enough of yours already
