I'm using a the standard zzr1100 master cylinder, operated by the pedal and a couple of rose joints.
The length of the clutch line is quite a lot longer than standard. probably 2.5 metres.
I'm not very familiar with banjo bolts, so can anyone suggest the cheapest way of connecting the two ends? I think both on the 1100 are 10mm
banjo.
perfect! thank you
