Hi all, I'm currently doing the clutch system on my bec with R1 engine and I have a question, how far does the lever on the clutch move to full
engagement? Will it move until it stops or will it pull too far past its normal operating position? I hope that makes sense, any help would be
great,
Marc
It's only about half an inch. I had a 6:1 pedal ratio on mine (modified from 3:1 as standard which was horrible to drive), if that helps.
[Edited on 19/4/17 by AdamR20]
