Was thinking of mounting a (cable) hand clutch on my BEC shift-lever, but then I thought that this might present a bit of a challenge if I spun the
car and started going backwards (would probably want to keep both hands on the wheel for as long as possible... and might not get to that clutch in
time to save the engine from damage).
Or are there any systems on the market that sense you are about to go backwards and will disengage the drive for you?
Is it necessary? I spun my ST1100 BEC at the North Wield track day a number of times. Sat for a few seconds to get my stuff together then fired up first time.....
There's an expensive mod for this on Hayabsa, to avoid starter AND engine damage in this event.
I'm guessing it's a one way clutch/bearing in the starter to engine link
Maybe a possible mod on your engine?
Sorry - it's an 09 CBR1000RR
never having had a bec etc,
apparently what you want is a sprag clutch
https://en.wikipedia.org/wiki/Sprag_clutch
The sprag clutch is what causes the problem (engages in reverse). What you need is a torque limiting clutch which most modern bike engines have to avoid kickback issues . Problems mainly occurred with 99-02 busa engines which did not have one.
Cheers - is a torque limiting clutch the same as a slipper clutch?
Spun on occasions in my MK Indyblade at track days, as the car losses grip and goes round the natural instinct is to dip the clutch. Never been a problem for me over many years of track driving.
Cheers.
Dipping the clutch would be my natural reaction as well.
Easy with a foot-clutch... but might take some getting used to with a lever-clutch on the shifter stick. And made all the more difficult with both
hands staying on the wheel trying to correct the slide until the very last minute - hence why I was wondering if there were any gizmo's on the
market that can help with such situations.
How about having both? or are you wanting the clutch pedal space for your foot?
I have a busa and managed to destroy a starter after spinning my car in the wet, dipped the clutch as quick as I could too.
No, a slipper clutch won't help.
Engage brain, as soon as you get into a 'passenger' situation, hit the clutch pedal (or hand device). Recover car to the paddock, remove
starter motor, remove end cap and wonder how something could destroy itself that badly and where all that brown dust has come from....
What makes this more damaging on a bec than a cec?
Hmm preengaged starters I've seen don't automatically engage the gear in a stall or reverse scenario, and retract it after start. Only during a start (solenoid on, gear moves, starting current supplied). You learn something new every day.
I am surprised like coyoteboy, is that really why bike engines don't like going backwards
Perhaps pre-engaged is the wrong word?
The starter on a bike is engaged permanently, but will only freely turn one way due to the sprag gear as mentioned above.
So when the transmission is turned the opposite way to normal running the starter is spun at a massive amount of turns more than designed due to the
gearing.
So if you are lucky it just destroys the starter,but has been known on Busas iirc to destroy the engine if the starter seizes.
The starter isn't pre-engaged, it's permanently engaged via a sprag gear. Think of it like the free-wheel on a bike. Turn the starter motor
and it drives the engine, once the engine starts (and the starter isn't driven the sprag gear free wheels. However turn it backwards and it
forces the starter backwards... just like rolling a bike backwards forces the pedals around.
The damage is caused by the brushes getting worn from rotating in one direction and getting a slight angle on their ends. When it goes the other way
they dig in and smash the com' etc to bits.
I went 7 years and quite a lot of spins before I was a bit late getting the clutch in and buggered a starter. I take a spare to track days (and tours)
now.
Originally posted by scootz
Cheers.
Easy with a foot-clutch... but might take some getting used to with a lever-clutch on the shifter stick. And made all the more difficult with both hands staying on the wheel trying to correct the slide until the very last minute - hence why I was wondering if there were any gizmo's on the market that can help with such situations.
Was thinking of mounting a (cable) hand clutch on my BEC shift-lever, but then I thought that this might present a bit of a challenge if I spun the car and started going backwards (would probably want to keep both hands on the wheel for as long as possible... and might not get to that clutch in time to save the engine from damage).
You might not get your foot on the clutch, but you will generally keep it firmly on the brake! That is usually enough to prevent damage.
It is obvious!
I agree that you should not over worry , else you'll never drive it
However in the heat of a few millisecond, just as your grip/skill runs out, on the track, going backwards, bouncing over the kerbs, into the infield,
I lost all sense of what pedals I was pressing
And blew the starter!
Only a cheap fireblade, and only the starter damaged.
If it was Busa motor, then you'd want to take out that insurance with the mod
