Is there a simple way of removing wires that go into the ECU connector? Its on a Yamaha R1 loom. Just curious as there are a few wires not needed and
i think it will look neater with them removed.
Any pics/vids etc would be of great use. Or the name of the pins of there is one?
N1
I'm not familiar with the specific connector but normally there is locking tang which can be released by tiny screw driver or piece of mig wire
by inserting above or below the pin from the front of the connector (opposite side to the wire entry).
Perhaps you can post a picture of the connector.
Davie
I think I would cut them off short inside the boot,making sure they can't short out
Originally posted by daviep
I'm not familiar with the specific connector but normally there is locking tang which can be released by tiny screw driver or piece of mig wire by inserting above or below the pin from the front of the connector (opposite side to the wire entry).
Davie
This is the sort of connector im on about. This goes into the bike ECU. Ive removes some from normal looms such as headlights but they have all been
normal terminals rather than round ones. I cant see a way to use a tool on the connector ive linked below
This is i think the connector pin....its a superseal feemale terminal so ive been told, but cant see a way of getting it out as from the front there
is no gap and the rears are sealed
[Edited on 2/5/18 by number-1]
Simply push on the white bars on the connector, don't panic, they won't come away from the plug. Just push them away from the plug. This
will release the pins, simply pull the wire that you don't want in the plug. When you've finished, push the white bar back into place.
Plug won't go into the ECU until the white locking bar is flush.
