It has been a number of years since I was last here, so long that I had to re-register.
I have a zx9r MK.
Went to take it out the other day and it was stumbling on idle. so thought I would balance the carbs. upped the idle control up to 2k, and let her
warm up. After about 5 mins she was nice a warm and then she simply died and will not idle.
Appears to have no spark.
Without doing a faluty towers on this car, any suggestions.
Battery is over 12volts
the engine spins over
stick coils appear fine and I have check the continuity with a multimeter
Any suggestions as to what could have happened?
Craig
This happened on a mates ZX9R BEC, after a lot of head scratching turned out to be the 100ohm resistor.
Thanks 40inches,
I have the wiring diagram and I can see the grey wire where the resistor is meant to be , but I actually cannot see the resistor. I have to assume
that it is hidden somewhere, as the car has been running for the last 10 years with the current wiring loom.
Could I simply run a spare wire with a resistor in it between the ignition barrel and the loom?
Craig
Originally posted by CraigF
Thanks 40inches,
I have the wiring diagram and I can see the grey wire where the resistor is meant to be , but I actually cannot see the resistor. I have to assume that it is hidden somewhere, as the car has been running for the last 10 years with the current wiring loom.
Craig
Thanks 40 inches,
Just surprised if it is that - what could have caused the resistor to stop all of a sudden.
Is it just a little 100 ohm inline resistor?
[Edited on 2/7/18 by CraigF]
