Anyone using r1 5VY clocks?
number-1 - 4/8/18 at 08:17 PM
Does anyone use R1 5VY clocks on their kit car? If so, can you tell me if the temperatures are C or F? Is there a way to change them? I cant see anything obvious in the manual but presume there is a way or is it done by the ECU?
N1
adithorp - 4/8/18 at 08:37 PM
European and UK bikes are in centigrade and can't be changed. US clocks might be in fahrenheit but I don't think so... or at least never seen anyone asking before so doubt it.
number-1 - 4/8/18 at 10:02 PM
Mate, The reason i ask......... the high temp issues ive been having........well...they are not high temps! My clocks are showing F and not C!!!!!!!! So when i thought the coolant was at 117......it was only 47c!!! Its taken me this long to notice there's an f and not a c!
Ive got a USA ecu but THINK ive got UK clocks
CosKev3 - 4/8/18 at 10:16 PM
I would guess USA bikes are in Fahrenheit, as all the yanks on R1 forums talk about temps in Fahrenheit
adithorp - 4/8/18 at 11:18 PM
UK+EU clocks are in centigrade. It's possible to between miles and kilometers but not c+F. I think the US clocks don't let you switch miles to kilos. Press and hold select when showing odometer (from memory) and if it doesn't toggle to kilos you've got US clocks.
