Hi all,
has anyone used these gear indicators? do they work well? is there any sensor on the 5PW that says what gear it is actually in?
https://www.amazon.co.uk/Motorcycle-Indicator-Xvs950A-Midnight-Xv1900a/dp/B07MY572D1/ref=sr_1_fkmr1_2?keywords=r1+5pw+gear+indicator&qid=156312950
0&s=gateway&sr=8-2-fkmr1
Thanks in advance
Got a HealTech one, of which this looks like a copy. Works ok and easy enough to fit. Picks up neutral switch feed plus revs and speed. There's a programming procedure (going through the gears with the wheels off the ground) and it calculates gear from revs/speed.
Ace, thanks for the reply.
Due to the way they calculate the gear, they won't give you a true reading if you change gear when stopped (except for neutral) or when coasting up to a junction with the clutch in.
Ok, that's fine, just after something that gives me an idea as this bike shift style is going to get some getting used to.
