I've got an R1 (5pw) powered fury. I broke the engine - there was a little puddle, the puddle turned out to be a pond, I didn't slow down
enough, ingested quite a bit of water...)
As with all good disasters, I'm looking for a happy ending and thinking of more power. The new 1ltre ngines seem to make more than 200bhp,
so...
Do any of them drop in without make modifications? Is there a preferred engine of choice? I want to keep the install as simple as possible - No dry
sump, etc.
I had a long chart with Andy Bates who was very helpful and he will either supply or install for me an cbr1000rr. It sounds like a well proven
reliable solution. However, it's not cheap!
What are my alternatives?
Mike
Whatever you get, just make sure it doesn’t make the car even more likely to throw a driveshaft at the bloke in the car behind who’s trying to keep up
with you! :-D
Wish I’d had the GoPro on...
Simply add engine mounts to your chassis (or adapt the ones you've got) and fit this?
What’s the power output of the gixxer?
I know mike is looking at either fixing his R1 or upgrading to something newer with more power - ideally around 200 to make it worth the expense and
hassle.
What age/ spec is it?
I know mike is looking at either fixing his R1 or upgrading to something newer with more power - ideally around 200 to make it worth the expense and hassle.
Have you heard the Big Bang / flat plane crank R1s? I think Raptor Sportscars have some experience there. I’d be very tempted in your shoes.
How handy are you with the tools Mike?
AB does good installs but as you have found he is not cheap by any means!
If you already have most of the BEC-related kit I reckon you could get a modern CBR1000 in for £3-4k if you get stuck in yourself. I dropped a little
bit lucky on mine and got a cracking engine for not a lot of money, but ended up with north of 200bhp for about 5 grand all in, having started with
bare CEC chassis. I did do pretty much everything myself though, only a final tweak of the map was outsourced. If you have a little time to wait for
bits to come up you can get some great deals - I have a spare very low mileage 2012 engine which cost me less than a grand, for example.
I had a 5PW Fury for a while - the CBR1000 is a totally different beast, so if it helps broaden your engine search I would say you absolutely
don't 'need' 200bhp... Keep things light and simple, it makes a huge difference. I think I remember AB saying they did a ZX14 to
CBR1000 swap and saved nearly 100kg!!
Sorry for lack of cohesion but keep thinking of extra info... any power figures quoted in the bike can largely be converted to wheel power figures in
a car, providing the install is good. For example a standard CBR1000 is about 175bhp in the bike, you'll see that at the wheels in a car due to
the less restrictive manifold (we don't have the physical size and shape of the bike constraining things) and the fact that we have to remap the
ECU (or it a Power Commander, etc) for the car application.
There is a LOT of info around for the CBR1000 and many people have done DIY conversions, it's probably the simplest install to make work reliably
(important factor!!). For me having a bit less bhp than the latest Kwacker or BMW is absolutely offset by the ease of getting the thing to work
reliably in the first place.
This is a long thread but covers my install in detail:
https://forum.wscc.co.uk/forum/topic/130867-the-lobster-88-se-rebuild/?tab=comments#comment-1382826
[Edited on 1/12/19 by AdamR20]
Rather than lots of power, what would be the low budget bike engine of choice these days?
Also is there anything that can be run on carbs and without an ECU?
Mike
This is a long thread but covers my install in detail: https://forum.wscc.co.uk/forum/topic/130867-the-lobster-88-se-rebuild/?tab=comments#comment-1382826
Ha! Fair play Chris
I don't think you need as much power in a Fury mind you, even with a 919 'Blade (probably 120-130bhp) mine kept pulling at 100mph... with
that little power a Se7en type car hits a metaphorical brick wall.
Just replace like for like and have a few grand to play with. Rotrex maybe?
Cheers all.
I read your build thread Adam. I can swing a hammer and hit my thumb, but my skill level isn't upto lots of fabrication.
I built my own fuel injection system for a westy years ago, so happy to play around but struggle for time.
The sensible thing to do is simply drop another r1 in.
I've always been interested in how the more recent CBR1000RR's would go without the air-box shower-injectors.
Obviously not very well if removed in isolation and run with the rest of the standard Honda kit. Instead deleted (along with the bike air-box) and
then some experimenting undertaken during a dyno session using a standalone ECU, different sized main-injectors, differing lengths of velocity stacks,
and fiddling with the fuel pressures?
Anyone gone down this road?
PS - love some of your out-of-the-box thinking Adam!
Problem with the CBR is it’s ignition system
The lack of a missing tooth set up makes it a complete bitch to run aftermarket ECUs with
This is further compounded by the fact that it’s pick up draws crank speed from 12 evenly spaced teeth on the flywheel
Knocking off one tooth as a trigger doesn’t provide a clean enough signal for most systems
I have done it by water jet cutting a 32-1 ring but then the flywheel has to be turned down to allow fitment clearance
It then has to be welded to the flywheel in an oil bath to stop the heat dissolving the glue bonding the magnets in the flywheel
When you turn down the flywheel it weakens it massively as the material is very thin to start with
Of the three we did one flywheel parred comany with the base material and two split the ring gear at high rpm
In short it really needs an external boss bringing through the clutch cover side to drive a trigger
A lot of work to do it though 😀
Why is that a 'problem'? Why on earth would you want to make life hard (and expensive) for yourself and run an aftermarket ECU, when the OE
one and a Woolich system (or ECU flash) will do everything you need?
Granted I guess there can be a tiny advantage if you are chasing every last bhp or optimising the cold start / enrichment maps (and charging customers
for the privilege), but for the hobbyist building cars in sheds / garages I don't really see it as a problem.
I do hope this isn't the start of 'Honda-bashing' because you've found a new toy to play with Andy
[Edited on 6/12/19 by AdamR20]
Not at all Adam
The CBR remains the mainstay of our fleet of cars and we will be using it for several years yet
The point of my post was to explain the difficulties of using aftermarket ECU’s with that particular engine
We are working on the new GSXR in much the same way we developed the iriginal package for the blade back in 2008 as it represents a step forward in
power and torque for our race focussed cars
It will however, not be a cheap package compared to the Honda with quite a sophisticated electronics package, ecu and a lot more to get it working
We will in time be looking at the new blade too however we have to know that a model run is going to be long enough to justify the huge development
costs in getting them car fit
Originally posted by AdamR20
Why is that a 'problem'? Why on earth would you want to make life hard (and expensive) for yourself and run an aftermarket ECU, when the OE one and a Woolich system (or ECU flash) will do everything you need?
Granted I guess there can be a tiny advantage if you are chasing every last bhp or optimising the cold start / enrichment maps (and charging customers for the privilege), but for the hobbyist building cars in sheds / garages I don't really see it as a problem.
Crikey - just looked at the most recent Gixxer 1000 figures.
199 bhp and 87 ft-lbs are pretty impressive - those numbers should creep-up reasonably well with the less restricted packaging space that a car
offers.
Secondary injectors again though, so I'm guessing that it'll be a similarly 'tall' install.
... and what about the 2016 Kwacker ZX10R - BONKERS! 207bhp!
Just a note in case folk are reading this thread, the race GSXR1000 engine has sold.
Thanks for all the interest.
Purchaser has a transverse installation, with his own ECU.
I therefore still have 2 complete K3-4 looms, one standard K3-4 ECU, and another ECU flashed for 10% more RPM. Full longitudinal exhaust system
(manifold, link and Westfield can) also remains.
Westfield Image split rims 9-10" (rear) and 7-8" (front).
GSXR750 (full race, bored 813cc, etc.) 163 bhp, complete engine, with dyno data to support.
Lots more from my racing retirement
Stuff4sale photo archive.
