"The Phormula KS-4 Knock Monitoring Tool contains all the advanced features of the Phormula KS-3 plus:
0-5v Analogue Data Out
The KS-4 contains a true 0-5v analogue data output. Data output rates are configurable at up to a blistering 100 samples per second and fully
compatible with all Data Logging Software, Engine Dyno’s, Rolling Roads and ECU’s. The 0-5v output can be integrated with an ECU to provide closed
loop knock control.
Phormula Knock Datalogged"
I assume from here that this knock sensor can be trigged up to the 0.5V aux connector on the megajolt lite jnr and monitor knock against RPM graph?
It’s spelt Phormula…
I’m out
