Hello all,
I have put an '08 R1 engine and loom in the back of a car.
Its all wired up but I am experiencing a small issue.
Basically, when I go to on and then crank, there is no fuel pump prime or crank. I find this odd cause I am getting
- all lights on dash working with no codes
- bike in neutral
- ex-up valuve does it check
- throttle system primes and does it check
- kick stand is up
I have checked the voltages and fuses around the starter relay and that all appears good.
Is there something I have missed that is causing the pump not to prime and allow to start. Any help would be great.
Does it have a tilt switch.
What ignition are you using.
Is it the bike ignition.
Does it have an Immobilizer.
have you check the tilt switch is actually working? Do you have a meter to check it or to check if there's power to the pump? Usually these kinds of things are something daft like a blow fuse, missing or bad earth, loose connection, faulty relay etc...
Yes it does, and that is positioned correctly, with the word UP, facing up.
start with the obvious and simple and test with a meter rather than assume things are functioning like the kill switch.
If I get chance tonight, I'll check my diagrams.
Did you get anywhere with this?
