Advice needed.
I was out for a quick blat yesterday when I noticed the engine temps was stupid high.
I stopped and switched engine off asap.
Coolant pump cover small inlet connection had corroded and snapped off ejecting all the coolant.
Engine wouldn't re start while it was hot but did a few hours later.
Apart from obviously replacing the pump cover is there anything I need to check/do to the engine as a precaution.
Thanks in advance
Brad
Is it not worth replacing the coolant pump and not just the cover?
Make sure the impeller blades aren't/bearings aren't knackered. That may be what's to blame for dislodging the cover.
The cover wasn't dislodged.
If you click the link and look closely at the cover you will see a 10mm ish connection. It's that what corroded and snapped off.
linky
[Edited on 1 by roadrunner]
The risk is, youve cooked the head gasket. Not a lot you can do short of a major strip down to check/change it. I'd put a new cover on the pump
and see what happens. Keep a close eye on water temp' and oil after. You could get a combustion gas leak tester.
https://www.ebay.co.uk/itm/TRIDENT-Block-Tester-Kit-Fluid-/184898393617?mkcid=16&mkevt=1&_trksid=p4429486.m46890.l6249&mkrid=710-127635-29
58-0
Sounds like a good plan Adi.
Hi Brad
Andy had his car over heat when he first built it it was the mech in front of the rad .
I know what you have said about the pipe but the mech is worth checking
Or replace engine with a pinto😀😀😀😀😀😀😀👍
G
Hi Jacko.
Engine has been fine for three years up until this pipe broke.
Hope you are well.
Originally posted by adithorp
The risk is, youve cooked the head gasket. Not a lot you can do short of a major strip down to check/change it. I'd put a new cover on the pump and see what happens. Keep a close eye on water temp' and oil after. You could get a combustion gas leak tester.
https://www.ebay.co.uk/itm/TRIDENT-Block-Tester-Kit-Fluid-/184898393617?mkcid=16&mkevt=1&_trksid=p4429486.m46890.l6249&mkrid=710-127635-29 58-0
It's this the same as a compression tester? If not, what is the difference?
As said its a reactive fluid that detects combustion gasses. Useful when the headmaster leak is still minor and not enough to show obviously by
pressurising the coolant. It socks gases through a diffuser in the bottom from the coolant res' using the bladder.
https://youtube.com/shorts/ZBhC86Bj13U?feature=share3
Of course it only checks cylinder to coolant leaks. Lots of other combinations of cylinder/coolant/oil/crankcase/atmosphere are possible.
@ roadrunner
Just looked at your image (thanks for posting the link). The Ø10mm outlet maybe to be a steel part inserted into an alloy part.
Could it be the coolant didn't have enough anti-corrosion/anti-freeze in it so the steel part corroded (and alloy was OK)?
I'm sure when you refill you'll mix in correct concentrations.
(Just an observation/thought - may have affected other steel parts of the coolant system as well)
Originally posted by nick205
@ roadrunner
