There appears to be a cheap ZZR1100 for sale on Pistonheads along with a few other engines including an ex Radical Powertec Busa engine. CLICK.
I know someone who's just picked up a useable ZZR1100 for
£150
Nowt wrong with it apparently. May try and get me greasy little mits on it for BEC Golf cart!
Simon
I'd buy it as a spare for £150. (But don't tell the wife!!)
Surely it would be perfect for that money... not pinched or anything!
I would check its engine number. Occasionally the cops would attend our meetings to check engine numbers. One turned out to have been altered, though
it was uncertain who had done the deed; the current owner or the former owner.
It was quite well done too. The old number had been welded over and then ground smooth. New numbers were stamped into it prior to re-spraying the area
with the correct engine paint.
The cops were suspicious because they saw a little bit of over-spray or pickling.
They recommend you sand any paint away from the area surrounding the stamped numbers.
The same applies to motorbike headstocks here. I had a tricked up Honda XR650 with, amongst other things, a re-sprayed frame. I was turned away from
the registration authorities and told to come back when the frame number was exposed.
Lots of bikes here with rusty headstocks.
My point exactly Rorty...
However, for spares may be good...
