Hey up,
Does anyone know what type of bolt needs to be used for the upper mounting of the R1 engine (ie the one that is at the front top when engine is in the
car)?
Oli
If it's the one I'm thinking of then it's M12 x 1.25. Don't quote me on that though
same as the wishbone bolts?
Nope, the wishbone bolts are M12x1.5mm, whereas the engine bolts are M12x1.25mm. Go to your local Yamaha dealer and buy some genuine items -
they're about £1.80 a piece!
[Edited on 22/3/05 by Coose]
Or get them off the shelf from work!
Cheers for the info
Ah, that would do it! Make sure they're at least 10.9 though, and not stainless....
Tell me to shut up if you knew that already!
Bit rude but you said it - Shut up Coose
Thanks for the help though,
Oli
