Slightly off topic, apologies. I've been storing a gsxr 750 this year. Last night put a new battery in it, it was very dark, and in the gloom I
touched terminals with the wrong polarity !!!!!! Can't get anything electrical to work. No lights, starter etc. I've checked all fuses,
OK.
It looks like I've blown something, any ideas on what ?
Rectifier/voltage regulator thingy?
This went on my mates XJ600 and had a similar effect.
HTH
Mark
[Edited on 12/4/05 by mookaloid]
Is there a fuse on the starter Relay. I know on some Kawasakis there is a 30amp blade fuse in the starter relay which I think covers the main power feed from the battery to the electrical systems, i.e. lights, CDi, etc.
Thanks lads !. i'll check it out tonight !
Once the bikes on the road again, I'll be able to get on with the tiger again !
Cheers lads ! Twas 30 AMP fuse that was buggered. Put everything back together and fired her up. Goes like stink ! renegade exhaust sounds great at 13,000 rpm !
