after some help please
we have a set of r1 clocks , r1 loom but no connector to plug into the clocks, can anyone tell me the pin order / location for the r1 clocks 99 carbed
so i can connect the dash to the loom
many thanks
marc
If you download the manual from here, it should have a wiring diagram in it (you'll need to
register first).
They are US wiring diagrams but if the 2003 version is anything to go by, its very similar to the UK loom so you should be able to work it out.
BTW, I will send you those roll hoop measurements etc across at some point, just concentrating on getting her back on the road at the mo
cheers chris
BTW, do I get any comission for doing some cross forum marketing for you
here?
[Edited on 14/4/05 by ChrisGamlin]
im sure we can do something
