i took the carbs off tonite as i sure there not set up correctly.while disconnecting the fuel line and cables i noticed that fuel was dribbling onto
number 1 throttle flap and quite a bit of it im wondering if thats my problem. ive taken the bowls of and checked the floats and the valves that work
the floats they seem ok not sticking ive cleaned out the jets ,checked the diaphrams they seem all ok.
there are 3 screws that sycronize the carbs how do i connect the vacuum gauges to set this up i cant see where they connect to ??? i have the 919
blade think it came out of a x reg bike.
many thanks
simon
