Im not at home at the moment but Ive got a funny feeling I may or may not have the speedo sensor for my r1 engine
what does it look like where is it etc
ta chris
quote:Flippin' 'eck - you'd better play the lottery this weekend with a hunch like that
meaning Ive most likely got it but couldnt be certain as I did take everything I could think of at the time
Ive got last weeks numbers if there any good to you
Not sure about earlier engines, but my 2003 engine has it bolted into the side of the block under the gearbox mounts. If you look at this pic, where
the gearbox side mounts to the chassis, if you look inbetween the mounts its just under there
R1 Engine Cradle
About...............................................................................here ^
ta i can just about see it
My 2000 is the same if that helps!?
