anyone have any pics of chain driven diffs all set up and what drive shafts were used?
thanks.
You have u2u
Bit busy at the mo but will send pics via email of several vehicles later this evening. I'm in the process of getting a setup made for the Toyota Mr2 diff & halfshafts, but won't be available for a month or 2 yet .
Siera lsd from XR 4 X 4.
Soon to have a bigger 52 sprocket (picture is 42) and be repainted.
diff1
[img][/img]
that siera diff is good does any one have a how to guide on how to build one?
Hi Craig
There are some photos of mine here
They're not all that clear but you can see the setup hopefully.
Wyn
Basically the diff is dismantled and a case made to go around the planet gears. You throw the propshaft drive bits away and the original outer
casing.
The planet case also needs a grease nipple as instead of oil, the diff is packed with grease.
You will need 2 bearings and bearing carriers to support the driveshafts.
The whole thing or just a sprocket can be bought here
Just come across a lsd sierra diff on
ebay
and
a
nother
NTDWM
[Edited on 26/2/2007 by nitram38]
You have mail!
XR2 diff and driveshafts here
Martin.
My now surplus diff
