I've read about BEC a couple of times, and I always start to wonder about these things...
* How does it work? how do you transfer the power from the engine to the wheels? are there any special parts required? anyone have pics?
* How do you connect the gearbox to the shift-device (couldn't find a better word to include both normal sticks and paddles)?
* What manufacturers make kits for bike engined vehicles?
* Why don't I see more vehicles with a front like a F1 car and only 1 rear wheel? I'm thinking that could be pretty interesting...
If the engine is front mounted, then a flex coupler is attached to the bike's outputshaft in place of the sprocket, and a universal joint
connects it to the prop shaft.
In a rear engined setup, the flexy coupling can be connected directly to the input flange on the diff, or a special chain drive cassette including
reverse gear can be used.
Check out the links on this site for different manufacturers.
If you're after three wheelers, do a search for them,as there are several manufacturers and forums, including one at Yahoo.
Maybe when you've finished the other one??????
Getting a bit cocky. Don't incur the wrath of the Master(of sarc), sic him Chris.
yours, Pete.
Sorry for the delay, I've been out in my car
Chris
BTW you're going to get a slap, teddy bear boy
