Had a good week working on the Locosaki, the engine's running and most of the bodyworks fitted. I've uploaded a couple more pics if you want
a look. So thanks to Jasper, Ben Marriot, Chris PTM and anyone else both on here and the Yahoo group who had ZX9R wiring problems/solutions. I
followed all the posts and worked out the wiring diagrams and the engine fired first time.
Cheers Steve
Well done bloke. it won't be long then till you can give yourself a good scare!
Excellent - and your always welcome at the Newlands Corner meet seeing as you're quite local.
Once the car is going I will be there. It's near Guildford isn't it? Thats only about 50 mins from here.
correct. enter 'newlands corner' into streetmap.co.uk and you should be able to find it....
Ned.
