Just thought I’d post a few photos of the electronic paddles that I have been working on lately, there are a couple of prototype sets doing the rounds
at the moment but I should be able to offer a fully developed kit in a month or so!
Let us know your thoughts
Thom
Looks superb and may be a much better option for my car with its VW Golf column over the manual paddles i was going to get from you.
Any idea on cost and does this include what i assume will be a solenoid at the gearbox end??
Nice
I have cheated a little bit and decided to use an off the self electronic shift kit (with throttle interrupt).
The kit is in the development stages so I cant put I final price on it just yet but I’m aiming for under £700, I know isn’t not locost but it is
substantially cheaper than any other electronic gear change system out there!
I have a trickshifter, so I supose all I would need is the solenoid?
It looks the dogs Cahoonas !!!
Have you got any of your other kits available?
I am using a punto column and 290mm steering wheel.
I have already mounted 2 X 10mm Rod ends on the column.
These are top and bottom and are 75mm centres.
[Edited on 15/4/2007 by nitram38]
Chris:
Your paddles went in yesterdays post so should be with you tomorrow!
nitram38:
I always have a few of the original kits available and it should be possible to modify it for your setup.
Originally posted by pathfinder
Chris:
nitram38:
