Can anyone answer this tricky question.
The jets that close the fuel off when the floats get to the corret height, is the little button that touches the float supposed to be fixed or move in
and out as if sprung?
I ask because after cleaning all the varnish from inside mine two are fixed and two move in and out. This leaves the floats at two different
levels.
