As title really. Looking for a engine loom diagram.
Yes - I can scan the Haynes later if no one offers 1st.
Pat...
do a search in this forum for shortie i think he did a PDF schematic for a 919 blade engine in a MK Indy, ive used that for the basis of mine.
I have a 919 Blade diagram if it helps?
CLICK HERE FOR DIAGRAM
borrow my manual if you want
Will bear that in mind Joe cheers. Someone e-mailed me a full wiring diagram including the car loom and splices between the two. Having it printed out
in A3 and A1 to use as a giant map.
I decided to go for that megablade engine so picking it up over the weekend hopefully. It has a modded loom already so will have to get it all sorted
in my head where everything needs to go as i'm at the stage of looming the whole car now.
Nice one Simon, you have been busy.
Mine looks like this now after a bit of tig welding here and there, made up another turbo exhaust exit pipe last night
How come you have made a different one?
Current state of mine
ive gone from a 50mm pipe to a 65mm pipe, in hope that it will help performance and expell the gasses quicker.
