Hi just got secondhand accusump and shortend baffled sump off fleabay does anyone have an idea where i should connect it into the engine could it be
fitted in where the oil pressure switch goes or is there a better place for it to be fitted.
regards mick
Oil pressure switch is the ideal place on the bird engine.
Thanks jon would you then tee the oil pressure switch back in with the accusump
regards mick
Yup, thats all I did.
