Exactly which wires do you connect together to cut out the side stand and clutch switch? Does this also disable the neutral switch and make the resistor redundant in the barrel?
Its the Green And White wire that comes out of the fuze box that has to be grounded.
It wont do away with the resistor since that is the grey feed to the ECU.
The neutral switch is seperate again.
I will see if I can scan the wiring diagram in. Will let you know later.
Cheers. I've got the wiring diagram but just wanted to check as wiring is not my strong point. The engine bay looks like lady and the tramps
dinner plate at the moment!
Heres a link to a copy of the wiring diagram from Alex Roebucks build diary:-
ZX9R "C" wiring diagram
[Edited on 30/9/03 by MK9R]
Ah found it on another thread (i knew i had read it somewhere). Ground the black and green wire out of the IC ignitor unit to cut out anti start
switches.
