new bits of kit for my zx12r imp a garret gt35r twinscroll turbo and twin dumps and 50mm bov
Yummy very nice!!
Hi there Paul
You should be out there bolting them on instead of sitting in that comfortable chair gloating quietly!!
Happy New Year
Mike and Sam
you need two external wastegates ?
give me chance only got it all last night and engine needs manifold making but im no welder so will have to get help with that as its stainless as are
the new flanges but it will get sorted i hope very soon cheers
paul yes i need 2 wastegates 38mm each
[Edited on 1/1/08 by imp paul]
it will end up a bit like this still have gt28r for sale new £350
Jealous, me??
Nah -- Not much
Are they chocolate?!
[Edited on 1/1/08 by Howlor]
spend spend spend, what about build build build.
hay up Joe hows things? do you know any 1 this way that's good at stainless steel welding? as i need some help doing the manifold
where abouts is you.
im in chesterfield joe if you know some 1 give me a pm cheers paul
suppose on a good day your an hour and half away, do you have welding equipment Paul?.
i have a 150 turbo sip mig but no good for stainless steel need a tig
It might be enough to get it all tacked together. I used my Mig (with stainless wire) to tack most of mine together, then took it to work to TIG.
Simon
Could be done as Simon says.
If you can tack it up, i will weld it up for you no probs.
Excellent new present you got yourself there mate, good luck with it! Look forward to seeing it when its finished
right so i need to get it tacked up so i need stainless wire and new gas joe thanks mate for the offer its good of you if i can get it sorted i will or can i tack it with normal mig wire? and then tig it
Welderman, where did you find those elbows - i like 'em!!
Cheers, Rich.
if you want Paul tack it up with mild steel, if your not polishing it etc, i can then put some small welds down grind yours off and then run over the top.
you need to see the LIST of turbo parts Paul has accumilated, it's huge.
I think he should start a project thread on my bike turbo forum (linky in sig)
ive just put this turbo against the map and engine spec. its way of the map lmao.the more revs the more off the map it is.
adam
