Hi All
I'm trying ot plumb in my 2005 R1 motor using my Polo rad. I can't work out where to plumb the outlet from the oil cooler. It appears to go
into a point near the bottom of the radiator. As I'm using a Polo radiator, the outlet form the oil cooler has to go into the top or bottom hose.
Any thoughts?
Here's a diagram from the Yamaha manual.
Wyn
[Edited on 7/1/08 by lsdweb]
see this thread, it's for the R1 although earlier version..
http://www.locostbuilders.co.uk/viewthread.php?tid=77919
[Edited on 7/1/08 by stuart_g]
I'd seen that. The later R1 looks different ( I had an earlier one)
Wyn
Hi Wyn it goes into the bottom hose on a polo rad
cheers malc
Excellent
Thanks Malc
From memory (and that diagram) on the bike, water goes from the oil cooler outlet into the rad inlet side, through rad and back to the engine (cooled)
via the bottom hose. So (and I don't like to disagree with Malc) it should go into the top hose on a Polo rad and return (cooled ) through the
bottom hose.
There's a flow diagram in the R1 manual as well as the one you've shown.
adrian
[Edited on 7/1/08 by adithorp]
I was just thinking i'd done mine wrong, but if it goes into the botton hose it will bypass the rad.
but malc does know his stuff
here's what i've done
[Edited on 7/1/08 by Johneturbo]
This is the best view I've got of my setup.
http://i189.photobucket.com/albums/z282/adrianthorp/Picture008-1.jpg
adrian
It doesn't go in either the top or bottom hose on the bike. the attached picture shows that it goes into the rad at the same level, but the
opposite side from the bottom hose / outlet to the pump. So it does get some cooling through the rad.
And here's the bottom hose exiting the rad.
...which is the inlet side of the rad...as I thought/said. ;-)
adrian
i have just finisehd piping mine up and i have put the bottom hose from the oil cooler to the top of the polo rad if you see the flow diagram it will
become clear
[Edited on 9/1/08 by r1 locost]
Thanks Guys
I got confused by the bike connecting to the bottom of the intake side of the rad!
I'll connect it to the top hose - it's a little bit more difficult but not a huge problem! Shame I've already prepared the bottom ali
pipe (drilled a hole!) for the additional input.
Regards
Wyn
