Airbox rubber bits
StevieB - 8/1/08 at 08:54 PM
Evenin' all.
Can anyone post a photo of what the airbox rubbers that need to be retained look like? I'm looking particularly for R1 carb examples, but anything will do at this stage
Just so I know I'm buying the right things.
Cheers.
[Edited on 8/1/08 by StevieB]
mcerd1 - 8/1/08 at 10:22 PM
These are from a carb'd R1 - sorry don't have many photo's of the setup (I sold htese bit when I got ZX9R carbs instead)
these ones are glued into the airbox (bellow), and clamp round the outside of the carbs
and you should also keep the rubber trumpets (although you probibly new that already) they just 'clip' over the bit in the middle of the carbs:
[Edited on 8/1/08 by mcerd1]
Coose - 9/1/08 at 03:31 PM
The rubbers in the top pic are the ones you need Steve. You don't need the trumpets unless you use the airbox, but if I remember rightly you're not....
StevieB - 9/1/08 at 07:43 PM
Defo not - TTS filter waiting to be collected from Post Office on Saturday along with jet kit - I've been a big spender this month!
