Just want to double check the wiring on my coils is correct?
Coil 1 .. Black/White wire ....positive
Yellow/Blue wire ....negative
Coil 2.. Black/white wire ...positive
Blue/Yellow wire ...negative
Many thanks
coil with yellow/blue wire is for plugs 1 and 4
blue/yellow is 2 and 3
Rich
just look at that avatar
Thanks for the info Rich..
Also the black tab on the coil is power and the coloured is negative?
[Edited on 26/1/08 by fluidslvr]
