hi all
i need to purchase a dynojet kit for my 919cc blade carbs,pump and high flow filter.
is ab performance still my best bet for this? anyone done this recently.
also im using the standard air box or should i change to the sausage type filter
thanks
simon
Sorry to post a reply which is identical to the last one I posted, but - Yes, ABPerformance is the best bet.
You can also then speak to Andy about your fuelling setup in correlation to your airbox and potential sausage filter etc.
HTH
Dynojet kits for early blades £102.00 with secure delivery to your door,if you are using the std air box,i can advise you on jetting/set up ring me on 01323 743733
