I have now got the blade engine firmly nailed into the Avon. Now I nead a prop.....I seek advice...where from?
MK? Autoprop? ST?
I will also require adaptor on the shaft.
Dont want to make one myself. Cocked that up on the last build with the rear of the gearbox breaking off even though the vibration appeared
negligable. It did it twice... I'm none to bright maybe I should have realised the problem first time...doh!
Anyway I dont want the ame sort of problem, but cost as always is a prime consideration.
i got mine from a place in luton
its either auto prop or reco prop.
they will make the WHOLE thing from the bit that bolts to the diff flange to the bit that slides into the box output shaft, to length specified.
it cost me 123 quid 2 years back
atb
steve
I think its the only ready made bit on my whole car....
