drive shaft bolts.
david cromie - 24/10/03 at 11:26 PM
I am using the MK gearbox adaptor and drive shaft, what is the correct bolt size to use, also I am using a lsd, what is the correct oil to use? david
Stu16v - 25/10/03 at 07:06 PM
Dont know about the bolt sizes, but if you are using a Sierra LSD it is just standard EP 80w/90 or similar.
