I'm building an Indy with a Fireblade engine. I need to order a prop adaptor soon but do I have to get one from MK or will one from
www.sprocket-adaptors.co.uk do the job?
I'm just concerned that MK have modified my prop so they know what size to make the adaptor.
Mark.
I would get it from MK if they are making your prop aswell. At least you know that it will all fit
this is what I was thinking. Didn't know if they would all be the same or not though.
Only thing is MK charge around £15 more. Better to be safe though.
I think they only make 2 sizes anyway and MK gave me the wrong size... but an easy fix
Make sure you get the bolts from MK for the connection to the diff as they are a pain to find.
Also, the connection of the adapter to the prop can be a squeeze depending on what engine so measure and cut your bolts carefully
Paul
I've got one of the sprocket-adaptors. Very happy with the item.
- Jim
Give Andy a call...
AB Performance 01449 736 633
