cant find speed sensor wires on Busa
finlay - 4/4/08 at 12:53 PM
hello all
i cant for the life of me find the speed sensor wires on my busa engine, i have a 3 pin connector on the loom for it but cant find the connectors on the engine
any help is much appriciated, also photos would be great
cheers
Finlay
richard thomas - 4/4/08 at 01:52 PM
When you say speed sensors, do you mean for the tacho or something?
finlay - 4/4/08 at 02:28 PM
yea, i was told that there shold be 3 cables to a 3 pin connector coming out of the crankcase area that should connect up to the busa instraments on the dash, what does your busa engine have ?
cheers
Finlay
richard thomas - 4/4/08 at 02:52 PM
If I remember correctly, there is a triangular 3 pin connector that comes from the case near the output shaft - that is the gear position sensor plug I think. There is also a plug that comes from the clutch cover area...can't remember what that is without my book.
OX - 4/4/08 at 03:23 PM
im sure its the wires coming off the sprocket cover that your after
Gerhard - 4/4/08 at 03:29 PM
I it's on the cover for the sprocket.
I have a picture in my photo archive.
[Edited on 4-4-08 by Gerhard]
finlay - 4/4/08 at 05:29 PM
thanks gents
well that certainly explaines why i cant find it as i m not using the sprocket cover, it never came with the engine, i m using a special machined slave cylinder barcket so that it fits in beside the gearbox output flange
oh no, hahaha,
any ideas on how i can hook it up once i get one from a breakers
cheers
Finlay
finlay - 4/4/08 at 05:31 PM
what set up are you using Richard ? any photos would be very helpful
cheers
Jason Fletcher - 4/4/08 at 10:14 PM
Finlay
I have a brand new Busa speed sensor along with both plugs. Let me know if you are intrested.
Jason
finlay - 5/4/08 at 11:33 AM
Originally posted by Jason Fletcher
Finlay
Jason
u2u sent
