hi all what is the code for a 06 r1 engine and are these a good moter for a bec
the code is : 5VY. Yes it is a good engine
It's what I'm using, but beware, it has a higher final drive ratio (compared to 04-05's) so watch what diff ratio you use if its going
in a sevenesque. You might not reach top revs in 6th.
Mines a Fury so not got quite the same brick like aero package.
adrian
[Edited on 12/4/08 by adithorp]
a 3.89 diff with 205/60r13 rear tyres will give you 61.9mph in 1st and 123.6mph in top which is about right for a 7.
i found when picking the diff for my fury that the real issue was 1st gear as to get a decent top end meant that 1st gear became very long, but thats
mainly due to the silly high redline
