Do you front engined BEC guys mount the engine with the output shaft directly inline with the diff input?
If so this means that the engine is quite far over in the nearside of the engine bay??
I am about to drop a zzr1100 engine in my brother in laws chevette and am just wondering if i can centralise the engine to help with exhaust clearance
and run the first part of a two piece prop at a bit of an angle instead of straight??
Nothing wrong with an angled propshaft, as long as the sprocket adapter and diff input flange are perfectly parallel. I believe most BECs have the
engines well over to the passenger side.
Plenty of photo archives here to check out!
I know you are supposed to run them a few degrees off to help the bearings but how many degrees max?
Can anyone point me to any photos?
I don't know about the max angle, but I have seen 3 degrees as a recommended value.
Sorted that engine yet David? I could do with a ride in a locost to get my enthusiasm for mine back.
popular question!
link
My conclusion from all that is:
1) Make face of diff parallel to face of prop-adapter.
2) Put diff to centre bearing perpendicular to diff.
3) Minimise the angle if you can, but 5degrees is alright.
Generally your degrees of freedom when putting the engine in are pretty limited. What I mean is the height is fixed, and the exhaust manifold to
top-rail is always a worry.
Oh! just re-read the question, I guess top-rail isn't an issue! Make sure those headlamps don't fall out though, I used to have one of
those chevettes (first car)
Matt
Originally posted by garage19
Sorted that engine yet David? I could do with a ride in a locost to get my enthusiasm for mine back.![]()
Chevette!
Is it Fibreglass?
850kg standard, how much can you get it down too?
V8's are more common in those
This is mine, not set up with a huge amount of science because I was restricted to where I could put the engine, but works fine.
Prop Angles
+/-7 degrees per UJ. Make sure that the UJ's aren't straihgt as this will cause flats to wear on the UJ bearings. Also, I don;t think it's *that* critical that the flanges are perfectly parallel - they never are on a live axle set-up!
My engine runs parallel to the chassis rails so the output flange and diff flange are far from parallel.
7 years & 15k (recorded) hard miles later no problems to date.
