if you was to buy a bike engine to turbo for a long term project what engine would you buy tp start off with.
adam
zx12r with gt35r twin scroll turbo
and you would need lots of ££££££££££
There's a book out there (can't remember the name of it) specifically about slapping blowers and turbos on bike engines....
Gives links to all the standard installations as well as DIY advice....
But yes, the Busa turbo install is a quite well trodden path....
Natuarally depends on budget.
I would say Blade engine because if / when it goes pop the engines are easy to come buy and cheaper to replace
but I only earn £5k a year
a car engine
I would say Blade engine because if / when it goes pop the engines are easy to come buy and cheaper to replacebut I only earn £5k a year
Originally posted by imp paul
and you would need lots of ££££££££££![]()
hi joe hope all is good with you i still have my imp at mb and now am missing it lots
it cost me £160 to take it there and same to bring it back
Thats the only problem with Malc of MB Customs...
He's virtually in another country! I mean everything else is perfect, his knowledge and ability - Spot on! His service and attitude - Spot on!
His willingness to help and advise people and not care about making a penny from it - Spot on!
Top Bloke!
hi joe hope all is good with you i still have my imp at mb and now am missing it lotsit cost me £160 to take it there and same to bring it back
zx12r with gt35r twin scroll turbo![]()
approx 500 to 550 bhp at 20 psi of boost
[Edited on 24/4/08 by imp paul]
If you're gonna stick a turbo on it, I too would go for a Busa.
Phil
Take a look at http://www.holeshot-racing.co.uk/ for ideas.
OK here we go again parts are je pistons low comp ape billet cam pulleys schnitz racing valve springs Carrillo h beam drag spec con rods billet clutch
basket billet cam chain tensioner kit balancer shaft removed 630cc injectors billet fuel rail dta engine ecu garret gt35r twin scroll turbo twin tial
38mm waste gates tial 50mm bov charge cooler aq mist water spray ape studs for the block and nuts cometic head gasket billet 360 swing sump aircraft
spec con rod bolts MB customs manifold bosch 044 grp a fuel pump aromotive .8 fuel reg that's just of top of my head
[Edited on 25/4/08 by imp paul]
